BANKS Holset HX35W?
pishta
I know I'm right....
Tustin, CA
I got an HX35w with some parts and I dont quite know what I got. It has a 'Banks Big Head' actuator, and a new Banks turbine housing along with a used HX35W compressor and center. I think the thing is a Banks 'quick turbo' package but I cant find any part numbers on the turbine housing that would tell me. All I know is its a 14cm housing, says 'banks' on it and is unused. similar sized to the stock Holset housing I also got with it. The actuator is used and says 43psi on it. Id like to use it on my 273 build with its wastegate (using a 9-12 psi actuator) as my other turbo does not have an integral one and thats hundreds saved if I dont have to buy a dedicated one. Maybe a 98-02 manual trans 5.9 Cummins application, anyone got one that can confirm it?
I'll check for you on Monday when I get to the shop as long as I remember.
5.9 cummins compressor housing with gale banks 14 exhaust housing. Got one on my cummins.
cool, sold the new 14cm Banks housing and Big head alone for $275, still got the stock Holset on there now with no actuator. Chaching
