Mine is a 67, and there is an allen head screw in the center of the window crank, then the door pull has a screw behind it, stick the screwdriver in with the phillips head facing the rear of the car. There are 2 screws on the bottom of the door pull/arm rest. Then use a flat head or a gasket scraper to pop the clips out all along the edge, these should stay in the door panel so be careful and make sure they come out with the panel and do not stay in the door.
