Barracuda Restomod
Topless69
The Twilight Zone
I see so few 67-69 Barracuda restomods it amazes me since it’s such a beautiful body style. Is it considered blasphemy because of this?
The 2nd Gens seem to have so much to work with, like good looks, decent handling and plenty of power. Does anyone else think it would be cool to see more of these? If you have pics of your Barracuda restomod let’s see them! I found this pic online (not my car) and think it looks awesome!
“Are you not entertained”
440
Ported Edelbrock RPM 75cc heads
Ross pistons, zero deck, 11.3:1
Eagle rods, bushed, 0.990 pins
Main studs, line honed
windage tray, circle track pan, 1/2” pickup
Ultradyne solid lifter cam
Weiand super stock six pack tunnel ram converted to EFI
FAST XFI EFI controller with traction control
29” core crossflow aluminum radiator
Mercedes fan and controller
oil cooler with temp controlled fan, remote mount filter and thermostat
T56 Magnum close ratio six speed
Twin disc clutch
Mark Williams 3-1/2” Aluminum driveshaft 1390 U-joints
8-3/4” rear with 3.90 gear and locker
Subframe connectors, torque boxes, additional frame for custom tank, square tube lower radiator support
modified front fenders for large diameter tire clearance
all new tinted glass
reinforced and welded K frame
1.12” T-bars
tubular control arms
adjustable aluminum strut rods
C-body tie rods
Pitman arm sector support
roller bearing idler
Borgeson steering box
custom valved Corvette large bearing PS pump with remote reservoir
Caltrac mono leafs and bars
Dr Diff 13” front brakes w/ Viper calipers and Baer rotors
Dr Diff 11.7” rear brakes w/ Cobra calipers and Baer rotors
1-1/8” master cylinder
Current front tire 255/40-18 on 18x9; car is setup to go as far as 285/35-18
Current rear tire 295/40-18 on 18x10; car is setup to go as far as 345/30-19
Wow both you guys have for a ton of mods on these and an awesome job integrating the upgrades into the old Cudas! Mosleyme did you name it Gladiator?
I don't exactly know the definition of restomod, but here's mine
It's good to see you posting again Al. Unfortunately no, I was in the process of converting it and another one came up locally that was less work to finish so, I went with that one. I still have the hood from you. :) Tell T we said hello!
Norm , is that the hood I drug out to you ?
Here’s mine and I agree, it’s one of my favorite body styles
I agree with both of you. I prefer the 67-69 Barracudas to the 70-74s, and 69 is my favorite year. I realize that may put me in the minority, but I like what I like.
440
Twin disc clutch
1.12” T-bars
C-body tie rods
Very, very nice build!!
