Battery Jump box recommendation
General Discussion
  1. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member
    20,146
    8487
    Dec 7, 2006
    PLANT CITY FL. and PERRY GA.
    Local Time:
    5:51 PM
    I’m always jump starting or blowing up tires that are low or flat i got to thinking I need to buy a jump box and if it has a compressor even better. So I thought I would see what the FABO members recommend. I don’t need one that will jump start a series 60 Detroit. But i want a good one. Thanks
  2. Jax_1975_Dart
    Jax_1975_Dart Well-Known Member
    203
    114
    Oct 19, 2019
    Jacksonville, Florida
    Local Time:
    5:51 PM
    We’ve had bad luck with jump starters and short lithium battery life.
    Best bet seems to be using ctek battery maintainers/tenders.
    I can’t recommend Milwaukee’s m12 battery operated tire inflator enough. Half of my dad’s cars are in a garage with no electricity. That m12 inflator has saved our butts countless times and I keep one in the trunks of all my daily drivers.
    Pic:
    • Thanks! Thanks! x 1
    • dukeboy_318
      dukeboy_318 FABO Gold Member FABO Gold Member
      44,066
      19849
      Jan 19, 2007
      No
      Local Time:
      5:51 PM
      I have a Viking 450 amp cordless and rechargeable jump box. It is a harbor freight special, but it cost 80 bucks. It will jump anything from a lawn mower to a twin battery Cummins dodge, any of our tractors to a 6 batteries, 12 volt Kenworth. I’ve had it about 3 years now and it rides around in my Jeep and I use it regularly. It’s small, about the size of a average novel, comes in an enclosed case with several cords to charge itself and various items like cellphones and tablets.
      normally, I rarely recommend stuff from Harbor freight due to the quality control, but I’ve recommended this to several people and not a one has had a problem.
      • SGBARRACUDA
        20,146
        8487
        Dec 7, 2006
        Local Time:
        5:51 PM
        Thanks @dukeboy_318. Thats the kind of info I’m looking for.
        • Like Like x 1
        • Mike69cuda
          Mike69cuda 66 is the new 17 FABO Gold Member
          2,391
          1906
          Jan 2, 2018
          Overland Park Kansas
          Local Time:
          4:51 PM
          I bought a little craftsman one shown in a thread called “miniature jump starter”.
        • SGBARRACUDA
          20,146
          8487
          Dec 7, 2006
          Local Time:
          5:51 PM
          Was it any good?
        • Mike69cuda
          2,391
          1906
          Jan 2, 2018
          Local Time:
          4:51 PM
          Pretty amazing. About the size of a cell phone. Started my v8 trans am twice & still had juice
          • DodgeLad
            DodgeLad Victim of Circumstance
            1,620
            1446
            Jan 15, 2014
            The Duke City
            Local Time:
            3:51 PM
            I use an AGM battery with leads connected to directly to it. It's motorcycle battery size. Nothing to fail but the battery. I charge it every couple months on the bench. You've got to insulate the big alligator clamps for storage. Goes in a cordura case in the back and doesn't take much space. Never had much luck with the integrated compressors. I have one that works, but it takes way too long. I'd guess 45 minutes to fill a 33" tire, but not sure because the battery has always died during the process. I just carry a bicycle pump now as a backup to my onboard air.
            Used one of these for years. Works good and reliable.
            450P-Auto Portable Compressor | VIAIR
            Running this now, it's really not that much faster than the 450P
            200 PSI High-Flow Air Source Kit | VIAIR Corporation
