Ok so this should work then. I was going to pick one up yesterday but wasn't sure.
This is the hold down. You will need the hooked rods as well. Battery Hold Down Kit 1970-71 B/E-Body 1970-76 A-Body, Battery Trays/Braces/Hold Downs/Hardware, 101-BHD04 Reproduction, NOS and Used Mopar Muscle Car PartsLooking for a Battery holder. What should i go with or should i fab something?
Wrong year.This is the hold down. You will need the hooked rods as well. Battery Hold Down For use with Battery Topper 1966-69 A/B-Body, Battery, 124-BHD6669 Reproduction, NOS and Used Mopar Muscle Car Parts
I did the same thing, then corrected it.1975 Dart.
Ah, I see that in another post. No information keeps us guessing and incorrect parts in the end. I corrected mine as well.Wrong year.
Those are complete pieces of CRAP. No offense to you.
Got one from Autozone and it worked good. thank you for your helpThis is more like or exactly like the OEM hold down.
If you are getting a "universal" be sure it fits on your battery (some batteries have exposed top caps and some universal hold downs won't fit between the caps.)
If you look on the body and the tray you find the openings the J bolts go into.
Also be sure the width of the hold down is wide enough for your particular battery size
If it was me I would just spend the money on an OEM style.
None taken... Figured if the OP was just lookin' for something to hold the battery in place, it'll work okay. It's a step up from telling him to use a bungee cord.Those are complete pieces of CRAP. No offense to you.
