BB oil pan discussion
I'd use the Milodon 30931. Triangulated low profile seven qt, set up.for a dash twelve external pickup.
......assuming you have manual steering.
I have no idea what would work with power steering.
440 Source has the pan you need. $149.95. And no you don't "need" the 1/2 in pick up or the external line for 10 second car.
FWIW, you may encounter an issue with a hard right turn. Not too long ago another member had to modify theirs..........
I was just getting ready to reply about my experience with 440 oil pans in my 70 dart when i saw this. I believe you are talking about me. The op could search for my post and read all aboutit. Fwiwthe 440 source pan in yor pic did not allow a right turn. As your pic shows the 893 pans notch is farther forward and might have worked but at the time all i could get was the 440 source and i didn't see any available this am but maybe there are. Anyway i had to fab an enlarged notch which as a pita but it worked. Edit i mean the notch is farther back or rerward when looking at it from under the car laying on you back
I already have the cnc edelbrock heads. Have a set of cnc stealth as well but they are on a motor.
Parts in hand and less money out of my pocket is my thinking.
Car is manual steering and has a c body pan on it now.Larger steering notch I believe than the original A body pan.
