Will k member for 340 accept rblock?
Thanks mcodecuda, Boss looking at putting 65 413 in his sport coupe, He wished they never got rid of Demon name. Have a great weekend.No unless you use a set of aftermarket conversion motor mounts.
Engine swap solutions for your classic Dodge, Chrysler, Plymouth
What year car?Will k member for 340 accept rblock?
Sorry ment raised block.Your title says "bblock" and your question says "rblock".
The R block is a 340 reproduction block, so yes, it will fit; using all the original peripherals.
By "bblock" I'll assume you mean the B or (RB) big block- yes, it will fit, but you need to use either the TransDapt or Schumacher conversion mounts. You'll need to find a big block transmission, small block transmissions won't fit a big block.
Conversion mounts or front plate.Sorry ment raised block.
