Locomotion
* Comp Cams Steel Retainers 740-16 - $40.00
- 1.437" diameter
- For 10* locks
* Comp Cams Beehive Springs 26918-16 - $145.00/set
- 125lbs @ 1.800"
- 367lbs @ 1.160"
- Spring rate: 373lbs/in
- Coil bind - 1.100"
- 2 sets available
* Comp Cams Valve Locks 641-16 - $20.00
- 7* locks
- Machined Steel
- For standard single groove 3/8" valves.
- Standard installed height.
* Crower Valve Locks 86108-1 - $30.00
- 7* locks
- Machined, Chromoly
- + .050" installed height.
* Comp Cams Valve Locks 623-16 - $20.00
- LS1 style
- 7* locks
- For single "round" groove 8mm-5/16" valves, including Magnum.
* Mopar Performance Race Coil P3690560 - $40.00
- requires 1/4 ohm ballast resistor.
* Taylor Plug Wire Separators 042860 - $12.00 for both.
- For 7-8mm wires.
- Blue
- One pack missing a 2 wire separator.
* Stewert Warner Oil Pressure Gauge 82406 (USED) - $15.00
- 5 to 100 PSI scale Full Sweep
- 2 5/8 in diameter size
- Analog gauge
- Uses Mechanical Sender
- Black Face with white pointer
(Does not come with light socket or oil line.)
All items (except SW oil pressure gauge) are new. Some have been opened only for inspection or mock-up.
Prices + shipping from Florida 32117
(Sorry, I don't do PayPal.)
- 1.437" diameter
- For 10* locks
- 125lbs @ 1.800"
- 367lbs @ 1.160"
- 2 sets available
- 7* locks
- Machined Steel
- 7* locks
- LS1 style
- 7* locks
- For 7-8mm wires.
- Blue
- Analog gauge
