dan5354
I was wondering if there is a way to bench test a gas gauge from a 67 barracuda? It has the voltage limiter inside. I have a new solid state limiter, but would still like to test the gauge before installing. Thanks
17 ohms, which shoud mean just about
empty,
Start by doing a search here, then post back
http://www.forabodiesonly.com/mopar/showthread.php?t=179517
http://www.forabodiesonly.com/mopar/showthread.php?t=264543
Basically, you need to supply battery and ground to the cluster. Make sure you feed into the INPUT side of the regulator
You need something for test resistance. You can buy resistors at radio shack
According to what I can find, the three test resistances for senders (in the C-3826 tool) are
L = 73.7 Ohms (empty)
M = 23.0 Ohms (1/2)
H = 10.2 Ohms (full)
