Stroker, do they make an adapter to put 3 225's under that? :-0
Holley 1920 wheezer is a peach. Get one, clean it out and rebuild it with a rebuild kit, about 30 minutes and 15 bucks. no fuss, no muss, forget about it. put a 2.25 inch head pipe off your exhaust manifold and run 2" back to the exhaust. IF you go super 6, intake is 100 EZ, kickdown is another 50-100 (why, No idea) and the 2bbl is probably the least expensive part of the kit. You can go Holley 350/500 2bbl if you have a manual trans with a Rochester(carter 2v) to Holley adapter plate. My humble advice, spend your cash on a nice paint job, interior, tunes and just enjoy it for what it is, a reliable cruising 6.
