Carnut76
Never tried them do they bolt up with no problem?Starter off like an 08 Ram Hemi is even smaller than the Dakota mini starter.
i just installed a mini starter on my 69 383 4 speed Cuda. i bought it from Summit and it was a bit expensive - around $180.00. i purchased it because it is a mopar licensed product. here are some pics. the terminal extension was a separate purchase off of ebay i think.
Do you have a picture of it bolted to a block? I would think that the solenoid would be really close to the block/hit the block..
Jim, as a fellow local, I should probably be talking with you. I got the mini starter for my 383 Scamp and just bought the same terminal relocators. Too close to the block without them.
Thanks Jim but I was referring to the 2005-08 Ram Hemi starter. It is smaller than the regular mini starter and stronger (1.7kw vs 1.4kw) - but I'm not 100% sure if it fits a BB. Rusty said yes and I also found a thread over at cuda-challenger.com where a guy said it fits. Anyways I ordered one (only $60) and give it a try.
I just installed the terminal extensions I bought off ebay.
"The Best" ones according to seller...
I'm not sold on using this. After having to enlarge the hole on small arm of "the best" one,
this still seems too close to the block. They should be facing AWAY from the engine, not toward. Not much is accomplished by using these extensions, IMHO.
Jim, how close is that wire connector to the block?
