So I've been doing some reading on oil for hydraulic cams and came across a lot of sights saying the oils now are removing the the level of Zddp in there oils that helps with the wear protection, that's critical for the hydraulic cam. Or so I've read. Anyway my concern is I am about to break in a new hydraulic flat tappet cam and would like to get the best odds possible for a successful break in. I've read rotella-t 15-40 is good for a break in any thought on this? I realize with the added cam break in additive. I came across a couple others like vr1 racing oil or something like a high mileage oil.
Anyway I just started assembling my motor again after wiping the number one exhaust lobe and Do not want to do this again for practice.
Any input on what some of u guys are using for break in and maybe what you use for around town cruising. Wiping the lobe was my fault I didn't get the correct pushrod length before breaking the cam in, just plain inexperience on my part not the cams fault. It wont happen again. I got my fingers crossed. I hope to have this engine back up and running by next weekend maybe. I haven't ordered my oil pump yet as I was running a regular oil pump before but am wondering about a higher flowing oil pump but don't have a deep oil pan and read they suck to much from the pan. Any thoughts on this one would be greatly appreciated as well.
