lemondana
BlackDart
I have a 67 Dart with manual drum brakes and am going to install disc brakes. I'm using the early power booster and a 70-71 master cylinder, with the 73 up single piston brakes. Where is the best place to get lines from? All I need are the master cylinder to distribution block lines. Do I need to get a proportioning valve. I called The Ram Man a couple years ago and he said a lot of people get away without using one, to try it first. Any opinions?
