Toms70Duster
Took the car out to the Mopar Maddness show. Ran it's best ever run...11.98 @ 113.25 in bad air. Can't wait to go again!
It's a 360 about 9.5:1, zero deck flat top pistons with closed chamber ported Edelbrock heads and 1.6 roller rockers. M1 single plane with a worked Holly 750 double pumper. TTI headers and a 3500 stall. 430 gears. 28" tire. It still needs some tuning and I'm learning as I go. What a blast, if I had known it was this fun I would have started 25 years ago!What's your combo ?
Small Block
Nice run and love the car/color. Looks like B2 Ice Blue.
It is a '71 grill. When I got it there was about 6 coats of different color paint on it. I cleaned it up the best I could. Wouldn't win a car show but it looks pretty good.cool car-- what year grill is that--71 ? i love it !
Yes, I intend on painting it. I attempted it before but the paint I have wouldn't stick to the gel coat. I need to do some research on the proper paint to use.Love that car! Any plans on painting the hood?
tom sand with 220grit use a good primer then paint.paint alone will not stik to the gell coat.just thut i could help..Yes, I intend on painting it. I attempted it before but the paint I have wouldn't stick to the gel coat. I need to do some research on the proper paint to use.
