Best way to clean tired aluminum wheels ?
grassy
Nova Scotia
I just read to use oven cleaner...
I remember spraying something a couple of years ago..then had t spray off with water...I think it was slightly acidic ?
Any advice ?
thanks
ian.
i use 1000 grit wet and dry sand paper light sand clean then mag polish as long as the wheel has not got a coat of clear on them
No clear. Just sad looking. I know there is a shine on them somewhere :)
Thanx
Ian.
Mothers Aluminum Polish works well with lotsa elbow grease....
A spray on spray off type sure sounds better though :smile:
Mothers mag and aluminum polish works well on a lot of stuff. Paste in a jar - wipe on rub off. If you need something easier - Have used some very aggressive spray on wheel cleaners from Eagle One. Been a while, so not sure what they offer currently
Any advice ?
thanks
ian.
No good,the acidic can etch the clear coat or the top surface. Mothers wheel polish /elbow grease,or possibly the Power ball setup.(safest bet,I.M.O.).
X2. I did this on an old set of U.S. Mags. There was no clear coat to worry about. There's no magic stuff for old aluminum wheels, just lots of sandpaper, polish, and days of elbow grease. Mine went from heavily oxidized from years sitting outside to where I could see my reflection. Lots of work.
I have my work cut out for me tomorrow..as long as it doesn't rain...thanks !
And the next day, And the next day, and the next....
If I remember right it took me about 10 hours per wheel to get mine like a mirror.
I really like them now but damn.
I think I started with 220 or 320 grit and stepped up to 400 then 600 to 1000 grit wet paper.
Polished with mothers wheel and aluminum polish.
I couldn't do them all at once. Had to let my fingers heal up for a few days a couple times.
I will see if I got some pictures and post them up. Proud of myself for staying with it till they
were done. Just make sure you really like the wheels, takes lotsa luv.
These were done about 8 years ago and have some dust on them so they could use a touch up.
But once you get them done they stay nice with minimal work.
i have a vibratory polisher at work.. throw it in clamp it down and 3 hours later... the shine is amazing.. front, back, barrel, totally polished.. beats the elbow grease!!!!
Do you have anything that you have run through that you could post a picture for us.
Before and after with mothers polish and power ball and about 2 hours of sweat!!!!
that looks real good- maybe I'll do that to the rims on my Stealth- the clearcoat is chipping on them in quite a few spots (I imagine that would remove it) and they need to be redone.
Guys I did up a set of slot aluminum rims last fall that were in my barn for over 15 years....
I used headlight restore and cloth.... then buffed them up...
I figured if they restore the headlights why not clean the crap off oxidized rims..
It works..
Once clean and polished dont forget to protect them with a good paste wax
I have a pair of original 1960s vintage 10" wide slotted wheels that had many, many years of oxidation. No way polish would cut through all that stuff. So I mounted them on the car, put the rear axle on jack stands, put a large piece of cardboard over the wheel/tire to protect the fender well and body then I turned the car on and put it in gear and let the wheel spin freely. Then I got me some 100 grit, 240 grit, 320 grit, etc, etc and a bucket of water and started sanding. It didn't take very long before they started to shine. The wheel spinning makes the sandpaper w/water cut 10 times faster and put the scratches in a pattern that disappears as you sand because the wheel is spinning in the same direction that you are polishing (circular). Also you don't have to bub back and forth for hours, just hold you hand perfectly still and let the engine/trans do all the work. The finer the sandpaper the higher the polish. I wouldn't recommend this method for newer rims but the old rims can be had very cheap if they are all corroded with oxidation but you can make them shine in less than 1 hour using the car as the buffing machine!!!
PS - if you use the idle screw to raise the idle to around 1500 RPM you'll finish a lot faster and the shininess/gloss will be even better. It's just like polishing a round steel bar on a lathe in a machine shop, the faster you go and the finer the sand paper the higher the polish. Eventually it will look like a mirror with very little work!!!
PS, PS - Another hint....Put a fan some where near the driver's door blowing back towards the rear of the car to keep the exhaust away from your work area or you'll get a headache!!!
Treblig
Nice satin finish Treblig. Just be careful when spinning the wheels while the car is on stands. and make sure the car is pointing out in case something happens. At the dealership I worked at, we spun them up on the brake lathe. That worked well. tmm
Yes, Care must be taken. I always use my heavy duty jack stands and make sure the car is sitting nice and solid. I'm always on the lookout for a broken (electronically) tire balance machine. You know, one that the balance electronics is ruined and all it will do is spin. That would be perfect for polishing rims. You can also put any type of wheel on it. I knew a mechanic that sent one to the scrap heap because he couldn't afford to get it fixed. Unfortunately I got there about 3 weeks too late.
The satin finish was my goal, didn't want it too shiny. In fact, I had to hit it with some coarser sand paper after I realized I had polished too much. This is the fastest method that I know of without having to spend a lot of time and money. Using a water bucket to keep the sand paper wet makes the sand paper last almost forever so it doesn't require many sheets.
HAPPY POLISHING!!! BUT BE CAREFUL...........
Treblig
ZEP-ALUM. Be careful or it will start to etch the aluminum. My boss uses this stuff on various metals and it is amazing what will just wash off with a presure washer. It is acid and will eat your clothes and hands if not protected. he uses a bug sprayer to apply, then washes it off with a pressure sprayer. it will take rust off of chrome as well.
He calls this the acid bath. I did this once tho, and got a phone call while it was on my wheels and it started to etch them, so no interuptions. good luck.
It works..
Great alternate use tip !
Actually...looking much better now...the son was working on them much of the day....it is amazing what motivates them :)
