On a small block in these early a bodies you don't have a lot of room for a fan. Is going with the old cast iron water pump required to make it work? I really rather use the later water pump if at all possible
Yeah, I'd rather use all the later stuffUsing the later water pump, requires using the later timing chain cover and a later radiator that has low passenger and high drivers water plumbing.
I thought it didn't matter which timing cover was usedUsing the later water pump, requires using the later timing chain cover and a later radiator that has low passenger and high drivers water plumbing.
