Best way,to seal?
Abodybomber
Breaking street machines , since 1983.....:)
Legendary Member
Arroyo grande ca
Getting rid,of all the rubber transmission line,on the cooler lines. Going to 5/16" hard line,custom bent as needed. Using off the shelf hard lines,hand problems with the inverted flare nuts,leaking at the brass inverted unions before. Was thinking,Permatex no.2. Any suggestions?
Cut the flare off and re-do it, there could be a burr on the fitting or on the flared line itself preventing a good seal. permetex wont seal a flared joint.
