Bezels.....
inkjunkie
Car is a 69 Dart. It has the shorter bezel in it, the one that ends at the heater controls. I have seen the "deluxe" bezels available thru a couple sources. The "deluxe" bezel covers the entire dash, over to the glove box which is also covered with a bezel. Can the "deluxe" bezel be used in place of the standard one?? Are the metal dash frames the same other than a few holes missing for the attachment screws?
The dash is a little different where the 2 different radios mount.
Forgot to mention that will heater and radio will have block off plates....don't want to spend the money on new bezels if they will not fit....
I have on of those that the heater portion has been cut out. The radio portion is untouched. If you are going to put a block off plate over it it may work well for you. If you want it shoot me a pm with an address and you can have it for the shipping.
