White letters on the inside.
This is the stuff we used years ago. With a good stiff bristle brush this worked awesome.
I used that for years dating back to the early 70's it worked great for dirty white walls and white letters. It does not work on these BFG stained white letters. BFG knows there's an issue and will warranty tires for the issue if they are new enough.Wesley's bleach white worked well years ago, just like many other chemicals of the past , the formula is probably not as strong as it was
I can get them white with thinner but they won't stay white long.Wasn't there a thread on here where someone familiar with chemistry found that acetone made them white again?
Yeah tried this. Not great
Yep, tried that too with the same results. It's in the tire.BF Goodrich, turning Brown for 4 decades and counting !
Naptha (Coleman camp fuel) works, but the best cure is a better brand of tires.
True that. I like the tires, tread, and letters but I will buy something else next time for sure.one thing that everyone should learn here is that this has been an issue for years. the lesson here is not to buy those garbage *** tires from here on out.
Yep. That PDF was a joke. Of course that came from BFG.Coloradohill's pdf tells it all!
Design flaw!
Funny how they say uv fixes the issue for a while.
They are saying that the sun can lesses the yellowing. Not cause it.Mine will discolor setting in the garage. If uv rays are causing the issue we should never
They recommend to get the tires some sun.
"However, under certain circumstances, these protective agents may become noticeable over time as yellowing or browning due to interaction with ozone. " I read this as ozone causes the chemicals to cause browning.They are saying that the sun can lesses the yellowing. Not cause it.
Read my post #48. The ozone is what causes the browning. It sounds like SPF 80 would be a better choice.must need their vitamin D![]()
