famous bob
mopar misfit
underdrive = bad . I was referring to overdriving the pump, which would take a smaller pump pulley, or bigger crank pulley . to speed up the water pump.440 source only has the under drive pulley in aluminum
Yeah I was asking them if they had a bigger crank pulley in the aluminum but they didnt they do have a stock pulleys 6-7/8 diameter so I went with stock 1-1 ratiounderdrive = bad . I was referring to overdriving the pump, which would take a smaller pump pulley, or bigger crank pulley . to speed up the water pump.
I have a 165 degreeWhat type thermostat do you have? Thermostat FLOW does more for cooling problems than what temperature it opens. You need a high flow thermostat if you don't have one.
I'll have to get a high flowI have a 165 degree
Just about got it all together and I don’t anticipate any cooling problems with this bad boy .
Time will tell pretty soon.
I have a 165 degree
I had a 195 in it put the 165 to see if it would helpThat's way too cool. You should have a 180-195. If the engine cooled off after the 165, there was something wrong with the thermostat it replaced. Lots of good ideas here, hopefully you'll get it worked out.
165 will delay the inevitable -----------I had a 195 in it put the 165 to see if it would help
Use a 185 high flow stat and pump, a three core 22” minimum, a shroud and a 7 blade fan. Sounds like stock B.B., it is. Paying attention to total timing it is a must. Make sure your hood seals are in place. It can be that easy! JMO!
I thot I`d change the thermostat, yesterday when putting ,mine back together from the pump milling process. Odered a hi flow (mr gasket) it came in and it`s exactly like I have been running.
What brand of "hi flow" stats are u guys using ??????????????[/QUOTE.
Milodon.
Which was disproved a long time ago as being 'the' source for overheating-issues.
But people rather like to remember myths and forget facts. Not saying the holes were not smaller than stock, but if the holes were actually too small the overheating would show up first with highway driving, not during idling.
Their waterpumps were the problem. The scrollwheel impeller is/was not peddling the same amount of coolant as the stock stamped impellers did.
I've tested it myself with a car that always was on the verge of overheating.
Tried changing housings, didn't help.
Tried a few different waterpumps and found the stock stamped steel impeller worked best and flowed the most coolant.
Maybe the factory did know what they were doing after all?
As for the topic-starters problem;
Are you running vacuum advance connected to intake manifold or ported carb?
Without a fan shroud it will not work. Been there done that, did not like it.Just about got it all together and I don’t anticipate any cooling problems with this bad boy .
Every fan needs a shroud to work, dont let anyone tell you different.
Funny that you replied today. I just returned yesterday from a 660 mile road trip, temp was between 80-85 degrees with mild humidity, double lane hiway so speed varied between 70 - 75mph, 3200 RPM. Car ran excellent and the temp was consistent.
It was fine on the around town cruzing as well but there was no extended idle time to worry about.
The 383 is pretty much stock with a few bolt ons.
The 14 - 15 MPG is a bit of an annoyance though.
Why the annoyance with the FM. It is 50 years old or so. Bet you got some attention on the trip! Enjoy life!
You got luckyFunny that you replied today. I just returned yesterday from a 660 mile road trip, temp was between 80-85 degrees with mild humidity, double lane hiway so speed varied between 70 - 75mph, 3200 RPM. Car ran excellent and the temp was consistent.
