Steve A
Member
Ok i dont have the dropped center link. Mine is only 2.5 " from top to bottom. so it is the 6 cyl link. Will a V8 link be different?
Are the pitman arm and idler arm mount holes on centerline of the link? If not, would mounting it so it is lined up in the clearance areas of the pan make a better fit? Did you say the idler and pitman arms are the same part numbers as the V8 models? Just kinda thinkin out loud so to speak.
