SixFourDart
1975 Plymouth Duster 383 big block Mopar 484/284 purpleshaft cam, 906 heads, aluminum intake, Holley carb, fenderwell headers. Three inch exhaust with 2 chamber flowmaster mufflers. Ten inch 3800 stall fresh rebuilt 727 trans with reverse manual valvebody. 8 3/4 rearend stock location with 4.11 gears. White interior with split bench seat and newer carpet. Aftermarket tach and gauges and B&M rachet shifter Jegs switch panel. The body is in good shape, the only rust is on the right lower 1/4 panel and a small spot in the left front floor pan. The trunk and frame rails are in very good shape. This car runs hard and strong and is a total sleeper. Has 14inch slots and drum brakes on all four corners. This car is in very good shape and runs strong. it will make someone a nice street car. This car has not been hacked up and does not have a roll cage. Open to reasonable offers-asking $6500OBO
Located in Illinois
[email protected]
Located in Illinois
[email protected]
