I was looking at a magizine yesterday and I saw something about plugging the suction hole om the block side where the pump mounts. If you use a external pick up line like one from Milodon. I blocked off where the Factory pick up tube threads into the stock location inside the block.
If the hole is plugged inside the oil pan wont that be the same?
