Big block hydraulic roller lifters, which ones or whats your opinion on Comps ?
I’m actually building a big block Chevy 496 with AFR heads and a Hyd roller as well. I talked with Chris Straub about the combo and bought most of the parts from him. Oil is very important with the hyd rollers as well. He looks at a number called centistoke. He says you want lower than 15 measured at 100c. I guess the Driven works very well. He has some impressive combos.
Chrysler B / RB & 426 HEMI V-8 Hi-Endurance Hyd Roller Lifters
Max Spring Pressure* :
140-160lbs seat / 380+lbs open (over 400lbs not usually recommended)
Something to keep in mind and often overlooked.
