Jims71duster
- Joined
- Nov 27, 2006
- Messages
- 228
- Reaction score
- 1
First off,, I posted here cause I know more people come to this topic so if its in the wrong place please move it.. Here goes,, A mildly built 383, kb 10.5-1 pistons, comp cam with matching springs and hyd. lifters. 850 holly,rpm edlbrock intake,msd ignition.
I started it for the first time and it cranked for about 15-20 seconds before it fired up. I checked the timing right away and it was at 11 btdc so I lifted it to around 2000 rpm for about 10 minutes ( at about 2 minutes I realized I never had a crank case vent so I took off one filler cap and there was a bit of presure in there).It seemed to be warming up a bit too much so I idled it down for 2 min. and shut it off. I repeated this one more time a hour latter. It seemed to run great. the third time I started it, it was back firing a little then the back firing got real bad. I took off the valve cover and found one push rod off and a different lifter was collapsed as well as a different lifter was destroyed. the cam wore it off until it had a hole in the bottom of the lifter. I already know the cam has to be junk and the motor has to come out and be ripped apart. WHAT THE #%^&& would cause this, every part was new and I was anal about perfect torques and cleanliness was perfect. I'm sure you can all realize how upset I am so If anyone could point me in the right direction in my search it would sure help me. side note here is that a machine shop did the short block and I did the rest.
