Treblig
Thanks everyone but with a broken starter bolt hole (as someone noted) I don't see a reason to buy it.
Treblig
Treblig
Never had luck with an FMX, slush box with the weirdest valve body you ever seen, looks like something out of an air conditioner.....
IF you had a motorhome tranny and needed the output shaft and tail housing, 25$ for that one is not bad.... Or, if you needed a valve body, or some other non-wearing parts from the inside... it would be worth picking up for some of those things (speedo gear and housing, dipstick tube, etc....)
