[SOLD] Big Block Stroker Build
coloradohill
Northern Colorado
Mopar Big Block Stroker Parts Located in 80534
I have changed direction with my Mopar build, up for sale are the parts I have collected.
Selling all as a kit. Not interested in separating at this time. I have a shipping discount that I can pass along to the buyer if needed.
1976 400 block #4006530, ( second most desired block) that is .030 over, decked .060, needs final hone depending on piston size. ( have documentation).
New set of 440 Source Stealth Heads, ARP bolts 445-3706. Comp Cams retainers 145-1003. 10 degree valve locks 145-1002, seals 101-1049. (documentation included). The previous owner of the heads cut the alternator mount for a custom look. You will need to use a "low mount" alt. kit. I have the pieces that can be welded back on if desired.
(1289.00)
2 Offenhauser #5498 aluminum valve covers ( rare ).
2 sets of factory tall valve covers.
1 #699 oil pan ( great for A-Body installation ).
New 440 Source water pump housing #200-1079B (blemished) (45.00)
New 440 Source water pump #113-1005 w/gasket and bolts. (35.00)
New set Comp Cams roller lifters #829-16. (515.00)
Chrome timing cover.
2 '516 cast iron closed chamber heads.
440 forged crank that can be cut for the stroker build.
2 727 Big block transmissions, 1 working from a running car, 1 core. ( not pictured ). ( photo is a small block trans not for sale, for illustration purpose only ).
Original rods and pistons from block, along with main caps, damper and pulley.
Basically you will need a rotating assembly, oil pump, rocker arms/pushrods, intake, carb, and distributor. ( I may be missing something).
Prices in parentheses are actual costs new. Total 1884.00, ( Does not include the other parts)
Asking 3000.00 Firm
Your inbox is full, I will pm you if you can make room. You can pm me with an offer if you want. I see what they are going for on ebay. I'll beat those prices. Where would shipping be to ?
Thank you
Thank you
Should be fine now...
