[SOLD] Big Block Z-bar - torque shaft and shifter linkage
68vert
Hot Springs AR
Rating - 0%
0   0   0
Looking for a big block Z-bar for my 68 barracuda . Has 383 ci. 4 speed.
Turns out the one a have is for small block :banghead:
The linkage needs to be for my 833 with hurst factory shifter that I believe is a 77-78 model.
Like to find today or I'll just order from Brewers. Just trying to save a few bucks.
Just a thought. If you end up at Brewers to buy the torque shaft only you might consider the TTI as it is modified for header clearance.
http://ttiexhaust.com/Category-MiscComponents/HardwareMiscParts.htm#zb
Thanks, good idea.
, but I'm sticking with the factory exhaust manifolds. I like the look of factory.
Plus I'm not too worried about too much performance. I'm thinking the 383 is going to be more than enough to push the little vert down the road. Crazy power in a vert makes me nervous :burnout:
What is Brewers,clicked on link?[sell window sports related decals]in the post sounds like a vendor for mopar hard parts?
