moturbopar
Well I have been saving up to build a pretty healthy 360
EQ heads ported
m1 single plane
10.6 compression, solid cam xs282s
holley 850 carb
Should be pretty healthy engine.
But I am thinking of selling the 360 stuff
and go with a 318 turbo motor.
to keep it more streetable, i would like it to run in the 11s have good idle and ba able to use my A/C
What I would build in its place
318 .030 over
my EQ heads
keep the M1
Forged pistons, 8.5 to 1
engle cam 218.050 int @ exst .489 lift 113ls 109icl
Scat rods
Forged 318 crank (is 69 318 crank forged?)
home made log manifolds
boost modified 850 holley
Trying to decide on turbo/s, I have a holset H2E 19cm housing
Or I might go to smaller .50 trim t3/t4 hybrid with a .63 ar and a stage 3 wheel.
Anyways the rest of the car is a 3200 lb 69 barracuda
Built 904 with Good 3500 stall converter
8 3/4 with 3.91, might go 3.23 or 3.55s dont know.
Think this combi is capable of my goals of streetable 11 second car?
EQ heads ported
m1 single plane
holley 850 carb
318 .030 over
my EQ heads
keep the M1
Scat rods
