Lookin to make 600+ out of a small block. Some body tell me what stroker kit and heads to go with. 408/410?426?440? Need a engine guys advice. thanx!
~ .040 over 360
~ Cast MP 4.00" crank
~ Eagle H-Beam 6.123" rods
~ Milodon 4-bolt steel main caps
~ Diamond Racing Pistons dished forged pistons
~ Total Seal's gapless top rings
~ Mopar Performance W-5 cylinder heads w/ 2.05-inch intake and 1.60-inch exhaust valves.
~ Mopar Performance's excellent W-5 tunnel ram manifold w/ twin 750 cfm Demon TR carbs
~ TTI's W5 1 7/8" headers
~ Crane 260/268 duration, and 0.420-inch lobe lift roller cam (this cam is very stable and easy on the valvetrain, and does not require
outrageous spring loads, and supplies the area under the curve)
~ Erson rocker kit (comes complete, assembled with rockers, shafts, spacers, and hold-downs)
~ oiling mods installing a bypass in the upper oil galleys, and rerouting oil to the #1 main
~ Speed-Pro's Competition Series bearings throughout
~ should get you....
RPM TQ HP
4000 561 427
4500 562 428
5000 581 553
5200 583* 577
5500 575 602
6000 562 642
6500 531 658
6600 525 660*
6800 505 654
