You-All here on FABO supplied lots of inspiration and help with the body/sheetmetal part of my project. As that part of the car starts to transition to being ready for paint, its getting closer to the stage of needing the engine done. I have been apprehensive about building my own engine, and had been interested in the posts done by MRL Mike.
Unfortunately as most of you know, Mike had to pull the plug. I have been reading up, and think I might like to tackle the job. I know enough can’t be said for experience, but the way to get it is to do it, right?
My 340 is currently .030 over, cylinders look good, I hope a hone will suffice, but may need to freshen up by taking it to .040, or 4.080. Trip to machine shop soon.
I originally thought I wanted to build a stroker, but have since decided to stay stock stroke. I think I would like to follow the formula Mike used in the linked thread.
MRL 340 for the 21st Century
A stock 340 lists compression height as 1.84, with a 6.123 rod. His formula uses a 6.250 rod, so I assume I would reduce the compression height by .127, am I correct?
I saw the thread on the Trick Flow PowerPort 190 heads. It seems the overall opinion is they are money better spent than on Edelbrocks.
So that I know if my math is correct, will a 4.070 bore, 3.31 stroke, flattop pistons with 5CC valve reliefs, .040 head gasket and 60CC Heads would give me a 10.6 static CR. Kinda high, so I would what…have the heads opened up some? Pistons shaved?
Biggest questions.. How does one go about finding 6.25 rods with the right big & small ends, Pistons with the right compression height and/or shaving them (I lose quench then, correct?) Are these custom made items? Does the cost get crazy, or are these considered minor modifications like I read that its cost effective to get custom made cams these days?
I have an Air Gap RPM intake & was figuring a 750 carb, possibly going to Sniper or FiTech down the road if it makes sense.
