No one ever oils the advance cam, and this is the results.
Went to a swap meet yesterday, found this distributer with dual reluctor's . Never knew they made them, apparently they made them in 1977, just never saw them before !
Where is all the moisture coming from?No one ever oils the advance cam, and this is the results.
View attachment 1715081937 View attachment 1715081938
PB blaster to get it apart, was rusted pretty solid from lack of oiling.Where is all the moisture coming from?
I never seen "Oil the Distributor every ***" in any owners manual. Just sayin! LMAO!That felt under the rotor should get a few drops of motor oil on it once a year or every 12k. Most do knot know about it that is why I posted this thread,
Lean burns did not have a vacuum advance canister. The computer on the air cleaner had the vacuum advance canister.Looks like Lean burn but didn't think they had vac advance.
I had one in an 82 New Yorker, it sucked. Got an 85 Fifth Ave that was owned by a priest, it ran flawlessly, I miss that car, it ran like a top.Those lean burns were great on Cordoba or something when they worked right, problem was, they never worked right.lol I usually ended up just putting an old single point dizzy in and never had anymore trouble
ThanksNo one ever oils the advance cam, and this is the results.
