New
CVF P/N SCRE2CR
Chrysler Small Block Crankshaft Pulley 2V
1967-1969 Small Block Chrysler Crankshaft Pulley - 2V (273, 318 & 340)
2 Groove V Belt Crankshaft Pulley (273, 318 & 340).
Designed for use with stock pulleys and brackets.
Made in the USA and CNC Machined at ultra high speeds for an amazing surface finish.
Fits vehicles with:
1) Drivers Side Lower Radiator Hose
(This identifies the early water pump which is shorter)
Crankshaft Pulley:
P/N SCRE2CR
Grooves: 2
Diameter: 5.4"
Overall Length: 2.5"
Bolt Pattern: 6 Bolt (bolts included)
$50 + shipping
CVF P/N SCRE2CR
Fits vehicles with:
Crankshaft Pulley:
P/N SCRE2CR
Grooves: 2
Diameter: 5.4"
$50 + shipping
