Bit by the Wind-door pillar split
loganscuda
This/These
san antonio
The wind blew my passenger door open further than it was supposed to go when my daughter got out. It split all the way across the Lower pillar just above the hinges mount. I looks like rust from the inner side is the culprit. My question is how to replace. Just cut the piece out and weld in a replacement. Is there anything special I need to do. Ill send a picture tomorrow when the rain stops.
Maybe get someone to cut one off a donor car . As said you may have some inner bracing deficientcies . Like to see the pics.
As Kendog 170 said, pictures would probably tell us more of the story & be able to answer your question.
