Factory air all rebuilt and blower works and a/c works and newly tested. but seems to be drawing arizona outside air (it doesn't keep getting cooler as you drive) I suspect i can prop open the blend door (or close it?)
**This may help troubleshot: I do seem to have a vaccuum issue in that my blower won't stay blowing through my vents unless I pinch off a vacuum line that goes to a round rubbervalve thing on upper left, which moves a lever). lines and the rubber thing are solid and newer looking.
ANY IDEAS or where can I find the blend door? Thanks!!!
