340wedge
- Joined
- Nov 14, 2004
- Messages
- 1,142
- Reaction score
- 826
I have the A01 light package and the fender mount signals work, exterior all work but the right side (passenger) side indicator doesn't flash on the dash either in turn signal or 4 way flasher mode. I have a new bulb, and the part the bulb goes in is new. I have twisted it in case the circuit board was the issue. My question is, where does the wire that goes to that bulb lead too, so I can test it all. Since the fender mounted signal works I don't know why the dash indicator doesn't. Thank You.
