Bulldog
so I've never painted a engine block before so I have a few questions,
>I sanded the block down and most of the paint came off but not all, should I prime the whole block anyway just to be on the safe side?
>I think the fuel pump on my 318 is aluminum, paint doesnt stick to aluminum does it? if not is there a chemical that will clean it up or not, I have most of the grime off but not all, And also the metal thing behind the water pump is also aluminum anway to clean that up aswell.
(off topic question)> I have the heads off the enigne can I clean the whole assembly in my parts cleaner what i mean is the valve, spring and retainers all together? or should I disassemble the whole first?
