AdamR
Big Member
I started blocking the quarters on my Dart today. My main concern is when to stop blocking, when to re prime with HI-Build Primer and when to make repairs with filler.
I have a few low spots I cant get out with just blocking because there are to close to stamping in the sheet metal like the gas filler and marker light. Those have high spots that make blocking the primer out impossible without hitting bare metal near the stamped sections.. Do I need to use a light coat of filler to even it out here ?
My other question is what grit should I be using ? I'm using 400 wet but the primer is real hard and cutting slow. Should I be using 220 instead ?
