blue 732 regulator
hangn0ut
rialto.ca.
Put together a just the basics wiring harness for my 69 dart strip only car. Have a constant output regulator. Which leads go where? Field and ignition,pigtail and stud. Which is which? Going to try a digital 7 box again so a fresh harness should keep it working properly. Thanks.
Field to screw (stud with nut) terminal.
Thanks Gerald. Ya know I couldn't find that in print anywhere. Its the little things.
