Wyrmrider
thanks kk
Makes a ton of sense... thank you!We used torque and angle to measure the clamp load... If we tried other oils, they would most likely fail in the multiple for angle...
We set a torque spec that we start measuring angle at, let's say 40 ft * lbs, so at 40 ft *lb the angle is now "set" to zero and we measure from there.. We would typically see angle run in the range of about 50° - 90° and we set a range that angle would be for the final torque... With "foreign oil" the angle readings would be higher and outside our angle range that was programmed in the machine...
3 in 1 or sewing machine oil would be light. Apparently a specific weight or type wasn't a big deal when those manuals were written. Everything now days is so specific and nothing else will work properly.That is pretty vague... It could mean anything from a light engine oil to something like penetrating oil...
And some folks were still pouring babbit for bearings LOL. I am glad to have seen and used some of the older methods. I know a guy who welded up the side of a piston that had a cracked ring land and re-turned new lands in the piston.... that was in the 80's and the piston was no longer available. 1.6L engine for racing. Amazing what can work...3 in 1 or sewing machine oil would be light. Apparently a specific weight or type wasn't a big deal when those manuals were written. Everything now days is so specific and nothing else will work properly.
There's McGuivers out there everywhere. I had a customer that had a couple teeth missing off his flywheel so he fired up his wire welder and made a couple teeth. Finished them off with a die grinder to give it a basic shape and it lasted about 6 months.And some folks were still pouring babbit for bearings LOL. I am glad to have seen and used some of the older methods. I know a guy who welded up the side of a piston that had a cracked ring land and re-turned new lands in the piston.... that was in the 80's and the piston was no longer available. 1.6L engine for racing. Amazing what can work...
Along those same lines, it's interesting that the flex plate has 6 or 8 bolts to attach it to the crank but only 4 bolts attach the plate to the converter, and those bolts only have 4 or 5 threads.
