Well, we did use the Summit tubing headers also.
Finally figured how to run a fuel injected Magnum on the dyno with a stock computer. Now we can re-program it and re-test the 360 Magnum with the fuel injection and not the carburetor. So as to not ruin anything while we learned how to use the Magnum computer, we thought we'd pull the grandaughter's 1998 300,000 mile 318 out of her truck and run it first. It made a lot more corrected horsepower than I thought it should.
RPM..............TQ/HP
1900...........272/98
2000...........269/103
2100...........269/108
2200...........278/116
2300...........284/124
2400...........294/134
2500...........296/141
2600...........292/144
2700...........291/149
2800...........284/151
2900...........282/155
3000...........280/160
3100...........283/167
3200...........280/171
3300...........280/176
3400...........280/181
3500...........274/182
3600...........270/185
3700...........275/193
3800...........276/200
3900...........276/205
4000...........281/214
4100...........274/214
4200...........269/215
4300...........262/214
4400...........258/214
4500...........246/211
The old girl has held up nicely. Even with 300,000 miles on it, it still held 63 psi oil pressure @ 4500 rpm and 56 psi @ 1900 rpm at the start of the test. It will be months before this 318 is rebuilt and rerun on the dyno, but it should be fun to see how it turns out.
