Bone stock 98 SS/T with 5.9 dyno sheet
dusted72
Thanks Hemiroid!!!!
Triangle, V.A.
I took the SS/T to the dyno shop today and finally got some pulls done on it. Not to bad for bone stock but it gives me a starting point in which to work from.
Mine doesn't have the restrictive stock air hat bolt mine has the clamp around the perimeter. I have a M1, 52mm throttle body, and a set of Gibson headers for it on the shelf.
Wow, I'm suprised. though there would be more. Put our stock Dakota R/T on
chassis dyno at Hot Rod power tour, stock. Had 200 hp at the wheels. Figuring
a 25% loss through drivetrain. Would be 250 like the Factory claimed.
Factory hp ratings are at the crank. Unless using the same dyno, and everyone is different in there readings, it is hard to get a good idea on how much gains you really made.
