Those with blowers or turbos. I'm running a magnum 360/408 at 9.1:1 compression with a Novi 2000. I'm guessing I will be around 12-15 psi when I get the car back on the road (first pull I hit 10 psi my stock 904 blew up as expected, but that's a whole different story). Right now I have timing locked out at 34* and I'm pulling 1.4* per psi until I get my air/fuel readings and adjusted properly. What is your target total timing for those running at full boost?
