scottylack
anybody know of a good ignition system for a Paxton blown 360???
MSD has a 6BTM box.
Same as a 6 series but with the tining retard Bill is describing.
I saw one for sale here, maybe MoparDude318 had it listed.
you can hook your vacuum advance canister up to manifold vacuum, when i hits boost it will go back to "static" timing.
I don't see any reason why that wouldn't work well, especially if you modified the slot (in the distributor mechanical advance mechanism) for mechanical advance so that it was limited to about 8 crank degrees. That would enable you to set ten degrees initial, for easy starting.
That setup would provide the 18 degrees mechanical you'd need for boosted power, and a lot more, once the vacuum advance kicked in after the boost goes away, for cool-running and better fuel economy.
The best of both worlds...:cheers:
Throw the retarded stuff in the ditch and run race gas.
Bill im just gonna run a uber loose dizzy in the blower car. 10 in the dizzy all in by 600, so 20 total. see how it goes from there.
but what you do is lock the mechanical to what ever you "boost" timing number is. then use the vacuum can (on the manifold vacuum) to achieve your off boost number. as soon as you hit boost your back to your correct number for boost.
"So, this will work, but only if the spring and diaphragm come from a distributor that was designed for a vacuum signal from a manifold and not the weak, venturi-vacuum signal from a carb..."
Isn't that what I said???
If you don't get a distributor out of a car (for this usage) that had an engine with manifold vacuum, you stand a very real chance of having that diaphragm fail, and that will not only deprive you of the desired advance, but will create a dandy vacuum leak that can lean-out your mixture an undetermined amount.
Cheap insurance... I'd do it, if I were you..
I run the MSD 6531 Programmable by laptop. you can save multiple ramps for say pump gas and race gas and be able to swap them in and out. Plus it has a start retard and a couple rev limiters such as a launch limiter and others..
Actually I think it 6530. I'll check.
just a Paxton at 6 psi on a 360 ...J heads with 2.02 valves, performer intake, demon 750, push button auto, dougs headers, 9.1 comp, high energy comp cam, 2800 stall
think Ill go with the 6BTM
