Boot....
Google MS25171 and see if you can find a size you like and order it from Aircraft Spruce.
Not sure of what it needs to fit, but how bout an old plug wire boot?
Hmmm....never thought of a spark plug boot....will try it next time I go out side..
If the spark plug boot does not work I will look into this. Man down the road is a retired FAA inspector...he recently rewired one of his planes....he might have a boot or two.....his son runs a plane repair shop in a local airport....might need to go visit Tony as well.....Thanks fellows...
Was a good idea but will not work...id is not big enough...od is to big...Thanks for the idea...
In looking for this boot I found what I was looking for...a copper buss bar so I can use stud style breakers...
