Ummmm, 440 & the 426 wedge or Hemi have the same stroke ....You do realize 426 is a shorter stroke and smaller bore than a 440 right? And the 426 couldn't beat the 440 until you gave her enough gear to rev ...so here you go ,shorter stroke reving higher will beat the long stroke bigger bore.
That's a couple things way better heads and RPM...
however... The same heads between two engines.....the shorter stroke will act as if it has bigger heads.
Ahhhhh... right?????
LMAO
