- Joined
- Apr 18, 2009
- Messages
- 4,306
- Reaction score
- 4,890
I have Borgenson box that I cannot use any more due not enough room for the pump and electric fan shroud. The box has close to 10 hours of run time, the Saginaw pump has been rebuilt and comes with a cooler that I mounted low on my QA1 k frame. I do have s small block pulley that will come with everything. Asking 600 shipped. You’ll also get both pressure and return hoses along with the fittings to go AN on the pump. The pitman arm size is 1.125. The aluminum pump brackets are not included.
