green1
Ok, the scenario; got rid of the eddy rich brock; installed msd atomic efi.
Sweet, once you realize the instructions are crap. Problem is; it was shifting early with the eddy, and new trans/throttle cable- left that for later. Installed the efi, got it tuned. Now time to fine tune shift rpm adjustments.(shifting too early at part throttle).
So I put throttle at full, adjusted kickdown/line pressure at full back. shifts too early;Forte built the tranny, 800 miles, sure not in there. Manually shift-fine.
From my old mech linkage days, I seem to remember being able to tell the trans to give more line pressure, earlier. With a cable set-up, I can;t figure out how. If you shorten the cable(it pulls from the rear, not standard push), it keeps throttle plates from wot.
Any ideas? Darn, I miss that slotted lever.
