You can do the same with 1" steel strips. And hey are lighter.
This is what I did with three 1" steel strips. No need to overlap the flange that's already on the LCA.
I've gone off course at the racetrack into a dirt hill.....and bent a steel rim, bottomed out a shock, dimpled up a shock tower....Didn't bend the Lower Control Arm.
Make sure to clamp the back near the adjuster pivot to take out any looseness in it.
