brackets and kickdown linkage
AdamR
Big Member
Bethel, CT
Hey guys, Im looking for pictures of the correct throttle bracket, return spring bracket and kick down linkage for a 73-340 or any thermoquad equipped 340. The stuff I have puts the kick down linkage at a weird angle and binds up under full throttle.
I saved these pics from another thread courtesy of Oldmanmopar
340 brackets are supposedly correct in orange and 318 in blue....Linkage is a PITA to figure :scratch:
I believe the bracket I have is correct, Looks like the one pictured but the linkage from the bracket to the carb is different.
Adam, this is correct 340 4barrel linkage '73. I know that because I pulled it off a a Cuda 340 car. I don't have springs hooked up yet I hope this helps.
I believe the linkage for B and E body is actually different. Not that it matter if it works.
Heres mine , untouched 73 340 , hope you can see
Awesome ! thanks. I have the correct bracket, I need a different upper arm.
